Topic "No Constructor for WinSCP.TransferResumeSupport"
dotps1
Contributor
I was working with the [WinSCP.TransferOptions] Class, i wanted to set the .ResumeSupport property. I see that that property should be of Type WinSCP.TransferResumeSupport. Which has two properties, State and Threshold, so this was my goal:
$resumeSupport = New-Object -TypeName WinSCP.TransferResumeSupport
$resumeSupport.State = 'On'
$resumeSupport.Threshold = 1000
$transferOptions = New-Object -TypeName WinSCP.TransferOptions
$transferOptions.ResumeSupport = $resumeSupport
However, for the first line i get the following error:
New-Object : A constructor was not found. Cannot find an appropriate constructor for type WinSCP.TransferResumeSupport.
I know this can be done:
$transferOptions.ResumeSupport.State = 'On'
$transferOptions.ResumeSupport.Threshold = 1000
But i would like to be able to declare my TransferResumeSupport Object separately. Is there a reason there is no constructor for this object type?
The reason is that you do not need to declare the TransferResumeSupport object separately.
What do you need it for?
dotps1
Contributor
I guess i don't really 'Need' it per say. Its just that the WinSCP.TransferOptions.ResumeSupport takes an object of Type TransferResumeSupport, So i thought i should be able to create that object, set its properties, and then use it when configuring the WinSCP.TransferOptions Object.
https://github.com/dotps1/WinSCP/issues/9
But the TransferOptions.ResumeSupport does not have a setter. It's a read-only property.
