Topic "get and Put failed"
Hi All,
I'm using the WinSCP 5.7.3 and calling the WinSCP through my application
Some time it work and some time doesn't work.
I've also enable the Log but it doesn't show/logged when its failed
But when the statment come to GET or PUT its abort the job.
The following command I'm passing through my application
Get =
Command = start /wait /D "C:\Program Files (x86)\WinSCP" winscp.exe
Parameter = /console /command "open ftps://Servername:Password@ -timeout=30" "get Source_File.csv G:\Master_Folder\Folder\Test_Folder\" "close" "exit"
hope its make sense!
Thanks for you help
Can you attach the log anyway? Both for successful and failed run.
How do you "call WinSCP through your application"?
