Topic "Session.DisableVersionCheck = true unnecessarily required"
vargonian
I get the error SessionLocalException: The version of ***\winscp.exe () does not match version of this assembly ***\WinSCPnet.dll (5.7.3.0). You can disable this check using Session.DisableVersionCheck (not recommended).
I downloaded both the exe and the dll in the same package, so there should not be a version mismatch.
The winscp573automation.zip package contains winscp.exe version 5.7.3. I've just checked.
Please double-check that you use winscp.exe from this package.
If that does not help, please attach a full debug log file showing the problem (using the latest version of WinSCP).
To generate log file, set Session.DebugLogPath. Submit the log with your post as an attachment. If you do not want to post the log publicly, you can mark the attachment as private.
glipper
I have the same problem:
Message : The version of D:\...\winscp.exe () does not match version of this assembly D:\...\WinSCPnet.DLL (5.5.5.0). You can disable this check using Session.DisableVersionCheck (not recommended).
Is it possible to activate "DisableVersionCheck" and "DebugLogPath" options directly in ini configuration file ?
Best regards,
glipper
For information, this problem occurs randomly (it works a lot of the time...).
Please enable debug and session logging and attach a full log files both for successful session and failed one.
To generate log files, set Session.SessionLogPath and Session.DebugLogPath. Submit the logs with your post as an attachment. If you do not want to post the log publicly, you can mark the attachment as private.
glipper
Thank you for your reply,
unfortunately, I can't activate full logs because the process is used in a production context and it's very difficult to reproduce this on a dedicated environment.
I got a look at the source code and it seem's the following command can sometimes return null or empty : "FileVersionInfo.GetVersionInfo(exePath);"
I don't know why.
In a first time, I am going to disable version check, then later i will try to integrate the last version 5.7: "Executable winscp.exe is included in .NET assembly package" --> should resolve my problem... i hope.
Best regards,
Gudpony
Hi Was this bug fixed in any of the recent versions. This same error is happening quite frequently for us. We have version 5.5.4.0
AN example of the exception :
WinSCP.SessionLocalException: The version of D:\.......\winscp.exe () does not match version of this assembly D:\......\WinSCPnet.DLL (5.5.4.0). You can disable this check using Session.DisableVersionCheck (not recommended).
at WinSCP.ExeSessionProcess.CheckVersion(String exePath, FileVersionInfo assemblyVersion)
at WinSCP.ExeSessionProcess..ctor(Session session)
at WinSCP.Session.Open(SessionOptions sessionOptions)
at com.luzern.co40.BLL.util.Ftp.UploadSFtp(String remoteFolder, String localTempFolder)
at com.luzern.co40.BLL.util.Ftp.Upload(String remoteFile, String localFile)
An issreset seems to rectify it every time but this is not ideal for our Production enviornment
It's not a bug. You are using an incompatible versions of winscp.exe and winscpnet.dll.
But the versions of each match
Please attach a full debug log file showing the problem (using the latest version of WinSCP).
To generate log file, set Session.DebugLogPath. Submit the log with your post as an attachment. You may want to remove other data you consider sensitive though, such as host names, IP addresses, account names or file names (unless they are relevant to the problem). If you do not want to post the log publicly, you can mark the attachment as private.
fbcjunior
I have the same problem... any solution for this bug?
