Topic "Add session/site name to Patterns to pass to Putty/Kitty"
braykov
I am using Kitty with WinSCP like this:
kitty.exe -title !U@!@ -cmd "cd '!/'" !U@!@
However I would like my kitty title to have the name of the session that I am opeing - currently I can only pass session hostname, username, etc.
This way when I have multiple sessions open in WinSCP I can have multiple Kitty sessions and the names will match the tabs in WinSCP.
Currently I am making errors, entering commands in one window thinking it is a totally different session.
The session param could be !S and an example terminal client path could be:
kitty.exe -title !S -cmd "cd '!/'" !U@!@
OK, good idea. Will consider it.
This request has been added to the tracker:
http://winscp.net/tracker/show_bug.cgi?id=1346
I'm sending you a development version for testing.
braykov
OK, I tested it.
The pattern list did not show any new patterns, but I assumed you implemented !S.
So I tried it and my title showed like this:
sftp://<username>:<password>@<IP>/
The idea was for !S to just provide the session name. The name that is showed in the tab caption and in the Login window (the left-side tree).
Furthermore, the password presented now, points a security concern.
The new patterns are
!# - port number
!N - session name
braykov
I would like to report a problem with this feature - using the test version that you sent me.
If the session name has a space in it, then Kitty fails to open with an error:
Unable to open connection to
Host does not exist
I suppose when constructing the string for the !N parameter you need to use double quotes.
I hope this helps and gets fixed for the new version Wink
I assume that using "!N" would help, right?
braykov
Yes, it works that way. But it is not that logical for a user to come up with this solution.
That's consistent with other patterns and even with how a variable resolution works in Windows shell (or even *nix shell).
RomanLangenbourg
!# - port number
!N - session name
I'm using Super Putty and usually I have not default port. But I can't pass it to SP - so connection refused and I need every time run it manually. Super time consuming and boring. Please, give pattern for port number.
Thanks a lot!
