Topic ".NET Assembly Session.MoveFile Method Problem"
Yros
I'm tring move zip files from one directory to another directory in the same server using by C#.
Despite app doesn't throw any erros, I can move those file, . I've red many articles but I haven't
found clear answer so far. Therefore I'm asking you for help. Below is a code:
try
Protocol = Protocol.Sftp,
HostName = "xxxxxxxxx.xxxxxxxxx.xxx.xx",
UserName = "xxxxxxxxx",
Password= "xxxxxxxxx",
SshHostKeyFingerprint = "ssh-rsa xxx"
string fileName = "aaa.zip";
string remotePath = "/sftp/xxxx/xxxxxx/Test" + "/" + fileName;
//string remotePath1 = "/sftp/xxxx/xxxxxx/Test/Archive"; -> doesn't work
//string remotePath1 = "/sftp/xxxx/xxxxxx/Test/Archive" + "/"; -> doesn't work
string remotePath1 = "/sftp/xxxx/xxxxxx/Test/Archive" + "/" + fileName; // -> doesn't work
session.Open(sessionOptions);
Console.WriteLine("\nFrom here:\n{0}\nto here:\n{1}\n", remotePath, remotePath1);
if (session.FileExists(remotePath))
session.MoveFile(remotePath, remotePath1);
catch (Exception e)
Console.WriteLine("Error: {0}", e);
return;
I guess It might be sth wrong with remotePath1, and I tred diferent combination of the remotePath1. Unfortunately, all of them failed. May be you have got better ideas?
Yros
Problem's partly been solved.
Method works fine. I've just discovered that file was transfered. However I have to press Refresh button in both directories(remotePath, remotePath1) to see it.
So another question is how to refresh sesion automaticly after the transfer?
You use the script as a custom command from WinSCP?
