Topic "access denied from .net but gui works fine"
k123kl23kl1kl23kl123kl123
when I use the standalone winscp.exe gui, I can upload and download files but I get 'access denied' errors calling similar functions in winscpnet.dll.
This is particular to one sftp site. the winscpnet.dll works fine at one site but the same command at another site fails. Can you compare the two logs to see why one site fails?
Any suggestions to resolve the error?
good.txt (14.33 KB) Private file
Description: this is the log uploading a file to one site showing the command works fine
bad.txt (18.91 KB) Private file
Description: this is the log of the exact same command as good.txt but the command fails at this site. I can upload however from the gui. What's the difference causing the error?
never mind. I fixed it by setting remotePath to session.homepath (and appending a '/' to the end if it wasn't already there).
