Topic "Charset issue with username during login."
PerGoetterup
I am unable to log in using SFTP to a site using a username with certain 8-bit characters. I try to login using the username "Per Gøtterup" and I get this error:
<error type="Exception" message="Account lookup failed: [Nt4] First LookupAccountName() for 'Per G�tterup' failed with the following error: Windows error 1332: Der blev ikke udført nogen afbildning mellem kontonavne og sikkerheds-id."/>
I can login just fine using PuTTY, Pscp.exe and FileZilla on Windows, as well as command line sftp on Linux.
From the log it looks like a charset issue.
This issue is being tracked already:
http://winscp.net/tracker/show_bug.cgi?id=1014
I have sent you an email with a development version of WinSCP to address you have used to register on this forum.
PerGoetterup
Thanks! - But I'm afraid it doesn't fix the issue. This is the log for my attempt:
<authentication attemptNr="2" userName="Per G�tterup" method="password"/>
<parameters failureReason="WindowsAccountLookupError"/>
Looks exactly like before.
PerGoetterup
Here's the log you requested.
username.log (5.72 KB) Private file
Description: (none)
You are right, it does not work for usernames specified on Login dialog.
I have fixed that and I'm sending you a new development build.
PerGoetterup
Finally back from vacation so I'm able to test... and it works perfectly! Smile Smile Smile
Thanks for your feedback!
