Topic "WinSCPnet.dll on Windows2000"
Bartman
Hi
I'm developping an sftp interface using WinSCP and WinSCPnet.dll release 5.7.3. This GUI has to run on Windows 2000 server.
Unfortunately, this release seems not to work on W2K server.
I get this error :
"WinSCP process terminated with exit code 0 and output "", without responding (response log file C:\Documents and Settings\XXXXXX\Local Settings\Temp\wscp1178.03CE0BB8.tmp was not created). This could indicate lack of write permissions to the log folder or problems starting WinSCP itself."
Which release have I to use ?
Thanks.
In what environment do you use the .NET assembly? (how do your run the code?)
Bartman
Hi...
Sorry for the delay...
The code should run under Windows 2000 Server SP4.
This code works fine on my Windows 7 developer machine, using last bin and dll of Winscp.
Have try to use older release of winscp... no success.
Regards.
Can you run WinSCP GUI on the system? Can you run WinSCP in scripting mode? winscp.exe /console?
