Topic "Large file = different editor?"
youradds
Is it currently possible / something that could be added, where you can define which editor to use, when files are different sizes?
Generally I use SubLime as my editor for programming. However, it doesn't do well on large SQL/log files (and sometimes crashes).
what would be great, is that I could set it to that anything greater than say 5Mb would open in something that handles it better (i.e doesn't try and process it with a syntax highlighter)
Is this possible?
TIA
Andy
Just use a file mask with size constraint is editor preferences.
http://winscp.net/eng/docs/file_mask#size_time
youradds
Thanks - that look like what I need. I'm a bit confused as to where I find that option though?
Cheers
Andy
Editor autoselection rule:
http://winscp.net/eng/docs/ui_editor_preferences
youradds
Awesome, thanks Smile I assumed you could only enter file extensions in there
