Topic "WinSCP.com file synchronization with filemasking not working propably (Solaris -> Win32)"
TR2N_
Hi guys,
i want to collect some log files from our Solaris hosts. I was doing it with this command batch file on our Windows host before i got the idea to filter some older files:
WinSCP.com <username>:<password>@<hostname> /command "synchronize local E:\UMD_Logs\04_ExternesTestsystem\srunavte2 /data1/umdav/log" exit
Because of the high amount of files i want to exclude the older ones and wanted to use the filter
filemask=">3D"
. But i can´t get it to work probably, regardless where i add it, it throws me errors:
WinSCP.com <username>:<password>@<hostname> /command "synchronize local -filemask=>3D E:\UMD_Logs\04_ExternesTestsystem\srunavte2 /data1/umdav/log" exit
or e.g.
WinSCP.com <username>:<password>@<hostname> /command "synchronize local -filemask=">3D" E:\UMD_Logs\04_ExternesTestsystem\srunavte2 /data1/umdav/log" exit
So what i am doing wrong?
Thank you for your help!
Kindly regards
Nico
WinSCP.com umdlogcp:T2%Rvrg!@srunavte2 /command "synchronize local -filemask=>3D E:\UMD_Logs\04_ExternesTestsystem\srunavte2 /data1/umdav/log" exit
This above is correct (except that you should use open to open the session, instead of specifying URL as a separate command-line argument).
What particular problem are you having with it?
TR2N
Hello prikryl,
when i enter following command on my Windows command line:
WinSCP.com user:password!@host /command "synchronize local -filemask=>3D E:\UMD_Logs\04_ExternesTestsystem\srunavte2 /data1/umdav/log" exit
...i get follwing output:
Searching for host...
Connecting to host...
Authenticating...
Using username "user".
Authenticated.
Starting the session...
Reading remote directory...
Session started.
Active session: [1] user@host
Unknown switch 'filemask'.
And i am back at the command prompt. I am not able to use the filter.
Thank you and kindly regards
Nico
Chances are you are using an old version of WinSCP. Make sure you use the latest one.
TR2N
Lol, you are right. My version was to old. It works now. But i don´t understand where to insert the OPEN command. When i run
WinSCP.com /open scp://user:password@sun /command "synchronize local -filemask=>1D E:\UMD_Logs\04_ExternesTestsystem\srunavte2 /data1/umdav/log" exit
from the command line, it works.
When i put this line into a batch file (sync.bat), i get following message:
Opening session using command-line parameter in scripting is deprecated. Use 'op
en' command instead.
Host "it takes my user(????)" does not exist.
winscp>
It seems that the batch script is parsing my command not correctly. How can i fix that?
Kindly regards
It's:
WinSCP.com /command "open scp://user:password@sun" "synchronize local -filemask=>1D E:\UMD_Logs\04_ExternesTestsystem\srunavte2 /data1/umdav/log" exit
TR2N
Hello prikryl,
first i want to thank you for your support, it is very appreciated! Smile
Sadly, i got this output when i enter the command:
E:\Data>WinSCP.com /command "open scp://user:password@host" "synchronize local -filemask=>1D E:\UMD_Logs\04_ExternesTestsystem\srunavte2 /data1/umdav/log" exit
Authenticating...
Authenticated.
Session started.
Using configured transfer settings different from factory defaults.
Comparing...
Local 'E:\UMD_Logs\04_ExternesTestsystem\srunavte2' <= Remote '/data1/umdav/log'
Synchronizing...
Copying file '/data1/umdav/log/log' failed.
Received error message from remote side: 'scp: /data1/umdav/log/log: No such file or directory'
(O)K, (A)bort: Abort
E:\Data>
I really con´t know, why he added a second /log or he tries to copy this. There is no log directory inside log...
Thank you very much!
Nico
TR2N
Hi Prikryl,
i have the log attached to this post. Thank you!
Kindly regards
Nico
Log.txt (18.09 KB) Private file
Description: (none)
The /data1/umdav/log is a symlink. WinSCP got confused by that.
Use a final path /data2/umdav/log instead.
TR2N
Hi Prikryl,
YEEEEEES! Now it works like it should! Thank you so much!!!
TR2N
Sorry Prikryl,
one problem left... When i enter the proper command into the commandline window directly, it works. But when i paste the line into a batch-file (.bat), i get following error:
too many parameters for command 'open'
What can i do? I am using the latest version. I want to add a job to the Task Scheduler for that, but i can´t because of this error.
Kindly regards
Most likely you have quotes wrong:
http://winscp.net/eng/docs/commandline#syntax
You need to show us your batch file, if you need help.
TR2N
Hi prikryl,
here is my batch file:
copyX.bat
cls
@echo off
WinSCP.com /command "open scp://user:password@host" "synchronize local -filemask=>3D D:\UMD_Logs\04_ExternesTestsystem\srunavte1 /data2/umdav/log" exit
I do not get any errors when running this command (which is correct).
Can you attach a screenshot of cmd.exe window, where you paste the command and execute it?
TR2N
That is exactly my problem. When i paste this command into a cmd.exe window, the command works as it should. When i paste this line into a batch file and excute it, the "too many parameters" error appears.
But when i paste the command into a .ps Powershell sript file, it works!??
winscp_test.ps1
.\WinSCP.com /command "open scp://user:password@host" "synchronize local -filemask=>3D D:\UMD_Logs\04_ExternesTestsystem\srunavte2 /data2/umdav/log" exit
--/> See attachment, it works!
winscp_test.bat
cls
@echo off
--/> See attachment, it does not work when this command is inside a batch file!
BTW: Can you please edit the first post i made with my guest account and remove the user/password/host informations?
Thank you and kindly regards!
Description: Executing the command with a powershell sript
Description: Error when using a batch file that has the WinSCP command included
Description: Entering batch file to execute it
Can you remove the cls and @echo off and show a screenshot for run the batch file again?
Any chance, you have multiple copies of winscp.com/exe for a different version of WinSCP, executing a different version each time?
Can you try to use a full path to the latest version of WinSCP in the .bat?
