Topic "The transfer is not remembering "newer only" choice if connection reset"
Delbin
Hi team,
I have initiated transfer of a bunch of files and choose newer only for overwrite prompt. Soon after the transfer started, the connection got reset so winscp automatically reconnected and resumes the transfer. But this time, winscp overwrites each and every file without checking which option i choose on overwrite prompt.
Please remember the option i choose for overwrite and keep using it after connection reset also.
Thanks.
Thanks for your report. Will investigate this.
