Topic "Problem with upload file in FTP"
Doctormom
Hello, How can I continue to upload files to ftp after disconnection? I'm try Close Open session but it's doesn't work! Help plaease!
Description: (none)
WinSCP should reconnect automatically.
Doctormom
this my logs file
1.txt (13.48 KB) [Download]
Description: (none)
I do not see any disconnect in the log.
There's just "Access is denied" error when uploading the file.
