Topic "transfer multiple files"
diane lupinski
how do I transfer more than one file at a time. Can I highlight multiple files to copy?
Sure, you can. See "Mark" menu. Also maybe article can help you.
diane lupinski
prikryl wrote:
Sure, you can. See "Mark" menu. Also maybe this F.A.Q. can help you.
diane wrote:
What is the Mark menu and explorer interface only brings up the host not my local directory so I can not transfer files this way.
diane lupinski
diane wrote:
Ok I found Mark, but if there are multiple files and we want to select 2 out of three files how do we select only those 2 files????
If you are using explorer interface, use the same way as you select multiple file in Windows explorer. For example by holding down Shift or Ctrl keys while clicking mouse buttons.
What about using drag&drop as in windows explorer? If you do not like this, use Command interface, which is intended to be controlled via keyboard.
