Topic "Weird issue with an uploading from a network mapped folder"
montonero
I've got a weird issue with an uploading to FTP from a network mapped folder after upgrading WinSCP from version 4.3.2 to 5.7.4.
There is a network mapped folder "Q:\folder1\folder2\folder3\folder 4" with files "file1" and "file2" (names are example).
The command like this (executed through a script or manually in a console window):
put "Q:\folder1\folder2\folder3\folder 4" "./path_on_ftp/" -resume
works in a strange way: on first call it creates "folder 4" on the target FTP path then throws an error
File or folder 'Q:\folder1\folder2\folder3\folder 4\file1' does not exist.
A call to an OS function failed
On second call it uploads file1 and throws the similar error about file2. On third call it uploads file2.
The same errors shows in the log file (without any additional details).
Uploading of the same files and folders from a local drive works flawlessly.
This error didn't occur in 4.3.2.
A log file from 4.3.2 for a comparison would help too.
montonero
Here's the logs. Also added sample command line and script.
logs.zip (4.63 KB) Private file
Description: (none)
montonero
prikryl
Any news?
Thanks for the logs.
montonero
Sorry, I will not be able to test it in a couple of weeks. Sad
montonero
Sorry for the delay.
I was finally able to test a debug version and it working without errors.
Just in case I've tried fresh 5.7.5 version - it still fails.
Sent you the debug logs.
montonero
Will this issue be fixed in 5.7 branch or it will be only in 5.8?
I wasn't able to identify the problem yet.
montonero
That's sad. Can I do anything more to help you figure it out?
Isn't the mapped folder pointing to a deduplicated drive?
montonero
Not sure about it. But it's possible. I'll try to find out.
montonero
Looks like it's deduplicated.
Thanks.
http://winscp.net/tracker/show_bug.cgi?id=1355
