Topic "Intermittent Connection Refused"
tlpitch
Yes, I'm troubleshooting a intermittent trouble! We have scripted WinSCP to automatically upload a file to an external SFTP server. This process works flawlessly for days, but then it will start to fail. It will fail until such time someone RDPs into the server running the job. Somehow simply logging into the server seems to correct the issue because 100% of the time the next job is a success. We don't have to open or do anything, just login and then log off.
I'm at a complete loss here.
