Topic "stay in the same local folder the next time i start winsc"
hi i just wonder if you can change something so you stay in the same local folder the next time i start winscp as i did when i shut it down. i thought you could do that with an older version but i may remember wrong
Check "Remember last used directory" on Directories tab of Login window. Save the settings to your stored session.
GRE
Is there a way of defining the default local directory for ALL sessions?
I have updated the F.A.Q. Maybe it will help you.
