Need to move files from one folder to the other, renamed with timestamp.
Harsh Narula
New Delhi, India
Hi All,
I need to move files from one SFTP remote location to the other.
I have been able to do that using the mv command.
However, I'm facing a problem. The move command is unable to overwrite files if by any chance I have files which are coming with same names. Is it possible to anyway, add a timestamp in the filename, this can help me remove any duplicate file-name issues.
PS: It has to be a solution through WinSCP scripting only. I cannot use .net/powershell.
Thanks in advance!
Karan Sharma
Selenium Java automation WinSCPMove file from one location to other and change the extension of file
Can someone help me to build the code to move file from one location to other and then change the extension of the file. I want to perform this action in WinSCP and Selenium Java code. Is that possible?
Karan Sharma
Re: Selenium Java automation WinSCPMove file from one location to other and change the extension of file
@martin - Thanks for the response, I tried as per your suggestion but I am getting error as
Can't get attributes of file 'H:\abc\STI_706_20220203_120225.dat'.No such file or directory. Error code: 2.Error message from server: No such file
I have tried with below command(changed slash) -
#try1
mv H:\abc\STI_706_20220203_120225.dat  /intf/u01/int/xyz/lmill/STI_706_20220203_120225.txt
#try2
mv \H:\abc\STI_706_20220203_120225.dat  /intf/u01/int/xyz/lmill/STI_706_20220203_120225.txt
#try3
mv H:/GDI/STI_706_20220203_120225.dat  /intf/u01/int/xyz/lmill/STI_706_20220203_120225.txt
Path specified in command is correct. Do you have any idea what could be the issue?
@Karan Sharma: The mv is for moving a remote file to another remote location (what this topic was originally about).
If you wanted to move a local file to a remote location, use put -delete:
put -delete C:\local\path\file.ext /remote/path/file.newext
https://winscp.net/eng/docs/scriptcommand_put#delete
