Topic "Element "cwd" not found in the log file"
mkozak
Trying to upload a file I get this error message on session.Open(sessionOptions);
I've attached the log files.
Protocol = Protocol.Sftp,
HostName = "virt01",
UserName = "root",
Password = "mypassword",
PortNumber = 22,
SshHostKeyFingerprint = "ssh-rsa 2048 xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx"
// Connect
session.DebugLogPath = Environment.GetEnvironmentVariable("USERPROFILE") + "\\AppData\\Local\\Commander\\DebugLogPath.txt";
session.SessionLogPath = Environment.GetEnvironmentVariable("USERPROFILE") + "\\AppData\\Local\\Commander\\SessionLogPath.txt";
session.DisableVersionCheck = true;
SessionLogPath.txt (6.61 KB) Private file
Description: (none)
DebugLogPath.txt (28.03 KB) Private file
Description: (none)
AjitKhodke
Can you post a callstack of the extension?
ESDS
mkozak
Error: {0}WinSCP.SessionLocalException: Element "cwd" not found in the log file
at WinSCP.CustomLogReader.WaitForNonEmptyElement(String localName, LogReadFlags flags)
at WinSCP.CustomLogReader.WaitForNonEmptyElementAndCreateLogReader(String localName, LogReadFlags flags)
at WinSCP.Session.Open(SessionOptions sessionOptions)
at F5_Add.Add.WinSCP(String source, String dest) in c:\Users\mkozak\Documents\Visual Studio 2013\Projects\F5 Add\F5 Add\Add.cs:line 1806
Can you post the logs using the latest version of WinSCP?
vpuchko
Hey,
I've got the same exception when trying to synchronize directories. I was using Syncplify.me Server! server and the following code to sync dirs:
                var sessionOptions = new SessionOptions
                    HostName = _settingsService.GetValue((SFTPSettings s) => s.InboundHost, string.Empty),
                    UserName = _settingsService.GetValue((SFTPSettings s) => s.InboundUsername, string.Empty),
                    Password = _settingsService.GetValue((SFTPSettings s) => s.InboundPassword, string.Empty),
                    SshHostKeyFingerprint = _settingsService.GetValue((SFTPSettings s) => s.InboundSshHostKeyFingerprint, string.Empty)
                SynchronizationResult result;
                using (var session = new Session {ExecutablePath = _winScpPath, DisableVersionCheck = true})
                    result = session.SynchronizeDirectories(SynchronizationMode.Local, localFolderPath,
                        folderPath, removeFiles: true);
                    result.Check();
I used standard SFTP server settings and added all required permissions to the user.
winscp_session.log (7.67 KB) [Download]
Description: session log
winscp_debug.log (34.22 KB) [Download]
Description: debug log
vpuchko
Found the issue, the issue was that winscp .net library version didn't match winscp.exe version, reinstalled from scratch and it worked.
