Topic "SSL3 alert write: fatal: handshake failur"
Lee-Kinetic
I just upgraded to 5.7.4 from 5.7.3. After upgrading when I try to connect to one of our 3rd parties, we receiving the following error. I reverted to 5.7.3 and I can connection without problem.
SSL3 alert write: fatal: handshake failure
TLS connect: error in error
Can't establish TLS connection
Disconnected from server
Connection failed.
Below is the log file.
. 2015-07-20 14:03:28.755 --------------------------------------------------------------------------
. 2015-07-20 14:03:28.756 WinSCP Version 5.7.4 (Build 5553) (OS 6.1.7601 Service Pack 1 - Windows 7 Professional)
. 2015-07-20 14:03:28.756 Configuration: HKCU\Software\Martin Prikryl\WinSCP 2\
. 2015-07-20 14:03:28.756 Log level: Debug 2
. 2015-07-20 14:03:28.756 Local account: XXXXXXXXX
. 2015-07-20 14:03:28.756 Working directory: C:\Program Files (x86)\WinSCP
. 2015-07-20 14:03:28.756 Process ID: 6984
. 2015-07-20 14:03:28.756 Command-line: "C:\Program Files (x86)\WinSCP\WinSCP.exe"
. 2015-07-20 14:03:28.756 Time zone: Current: GMT-4, Standard: GMT-5 (Eastern Standard Time), DST: GMT-4 (Eastern Daylight Time), DST Start: 3/8/2015, DST End: 11/1/2015
. 2015-07-20 14:03:28.757 Login time: Monday, July 20, 2015 2:03:28 PM
. 2015-07-20 14:03:28.757 --------------------------------------------------------------------------
. 2015-07-20 14:03:28.757 Session name: XXXXXXXXXXX@209.16.XXX.XXX (Modified site)
. 2015-07-20 14:03:28.757 Host name: 209.16.XXX.XXX (Port: 2121)
. 2015-07-20 14:03:28.757 User name: XXXXXXXXXXX (Password: No, Key file: No)
. 2015-07-20 14:03:28.757 Transfer Protocol: FTP
. 2015-07-20 14:03:28.757 Ping type: C, Ping interval: 30 sec; Timeout: 15 sec
. 2015-07-20 14:03:28.757 Disable Nagle: No
. 2015-07-20 14:03:28.757 Proxy: none
. 2015-07-20 14:03:28.757 Send buffer: 262144
. 2015-07-20 14:03:28.757 UTF: 2
. 2015-07-20 14:03:28.757 FTP: FTPS: Explicit TLS; Passive: Yes [Force IP: A]; MLSD: A [List all: A]
. 2015-07-20 14:03:28.757 Session reuse: Yes
. 2015-07-20 14:03:28.757 TLS/SSL versions: TLSv1.0-TLSv1.2
. 2015-07-20 14:03:28.757 Local directory: C:\Users\XXXXXX.XXXXXX\Documents, Remote directory: /users/XXXXXXXXXXX, Update: Yes, Cache: Yes
. 2015-07-20 14:03:28.757 Cache directory changes: Yes, Permanent: Yes
. 2015-07-20 14:03:28.757 Timezone offset: 0h 0m
. 2015-07-20 14:03:29.006 Connecting to 209.16.XXX.XXX:2121 ...
. 2015-07-20 14:03:29.006 TLS layer changed state from unconnected to connecting
. 2015-07-20 14:03:29.006 TLS layer changed state from connecting to connected
. 2015-07-20 14:03:29.006 Connected with 209.16.XXX.XXX:2121, negotiating TLS connection...
< 2015-07-20 14:03:29.006 220-EvansSecureFTP X2 WS_FTP Server 5.0.4 (450703966)
< 2015-07-20 14:03:29.226 220-Evans, Simpson Secure FTP
< 2015-07-20 14:03:29.226 220 EvansSecureFTP X2 WS_FTP Server 5.0.4 (450703966)
> 2015-07-20 14:03:29.226 AUTH TLS
< 2015-07-20 14:03:29.751 234 SSL enabled and waiting for negotiation
. 2015-07-20 14:03:29.886 TLS connect: SSLv3 read server hello A
. 2015-07-20 14:03:29.886 TLS connect: SSLv3 read server certificate A
. 2015-07-20 14:03:29.886 SSL3 alert write: fatal: handshake failure
. 2015-07-20 14:03:29.886 TLS connect: error in error
. 2015-07-20 14:03:29.886 Can't establish TLS connection
. 2015-07-20 14:03:29.887 Disconnected from server
. 2015-07-20 14:03:29.887 Connection failed.
. 2015-07-20 14:03:29.887 Got reply 1004 to the command 1
* 2015-07-20 14:03:30.253 (EFatal) Connection failed.
* 2015-07-20 14:03:30.253 SSL3 alert write: fatal: handshake failure
* 2015-07-20 14:03:30.253 TLS connect: error in error
* 2015-07-20 14:03:30.253 Can't establish TLS connection
* 2015-07-20 14:03:30.253 Disconnected from server
* 2015-07-20 14:03:30.253 Connection failed.
Please attach log files both from 5.7.3 and 5.7.4 on Debug 2 log level.
