Topic "SFTP Task editor issue"
hetty4jesus
I am trying to configure SFTP task editor in SSIS 2008R2. The problem is that there is no where to input filename variable under the local parameters in the GUI.
I created the followings variable in SSIS:
sftp_Host==>xxx.xxx.com
sftp_Port==>22
sftp_usernamet==>myuser given by customer
sftp_password==>Password assigned by customer
sftp_source==>c:\customerdata\
sftp_target==> /inbound (customer sftp site)
sftp_Filename==> Customerdata.txt
In the GUI, I can't seem to find a place to put the variable for the sftpfilename.
I am not a C# developer so I do not know how to do this otherwise.
I would appreciate any help.
Hetty4jesus
What is SFTP Task editor?
hetty4jesus
I installed the SSIS extension from codeplex to work with winscp. This creats sftp task in ssis control flow.
The screenshot was attached.
I do not see any screenshot and I do not know anything about the extension.
Why don't you ask on codeplex?
Can you at least post a link to the extension?
