Topic "Little problem with timestamps"
eXemonY
It must be an stupid question, but i can't figure it out by myself..
Well the problem I'm having is, my client saves files with the timestamp DD/MM/YYYY HH:MM:SS and my server does it as DD/MM/YYYY HH:MM I would like to know how i can mask the timestamps of my client while synchronizing it.
Hope you can understand it, not native though.
Thank you in advance.
I'm not sure I understand the problem. What is "my client"?
eXemonY
First of all, thanks for your answer.
Well, my computer is the 'client' and I save the files in DD/MM/YYYY HH:MM:SS, now I encounter the problem while I try to synchronize my files with my NAS that saves the modification date as: DD/MM/YYYY HH:MM, so, when I compare them it always says I have a newer one as it has seconds.
I cannot connect my NAS through SFTP only FTP, so I cannot use the 'synchronize timestamps' option.
Thanks again, hope you could help me Wink
If the FTP server reports times with minute-precision only, WinSCP recognizes that, and considers minutes only, when comparing files.
eXemonY
Thank you, hope it helps. In that case I synchronized 5 files, all starting as: 'Jesus-MINHO_***' and all of them were already uploaded. Thank you Wink
log.log (49.94 KB) Private file
Description: (none)
OK, this is a known bug:
http://winscp.net/tracker/show_bug.cgi?id=1342
WinSCP 5.7.5 with the fix will be released later today or tomorrow.
