Topic "[?] How to only export/import sites"
Currently WinSCP has the following options under the Tools menu:
- Import/Restore Configuration...
- Export/Backup Configuration...
But this also exports/imports the full settings.
I need to export only my saved sites to give them to other users to import.
The current export/import feature causes problems because I have other settings, like custom editor, which other don't even have installed on their PCs.
Anyway, I don't want to force others to use my config. I just need to be able to provide them with the sites.
Is there a way to do this with WinSCP?
Just remove all the [Configuration\*] sections from the exported INI file.
