Topic "Stream write error"
D@rkrunner
Now Ive had it. Sad I managed to transfer a single file, and then.....STREAM WRITE ERROR...
Now every file I transfer, get to about 93% and claims STREAM WRITE ERROR.
If the file is small , under 10Mb no problem.
I downloaded the newest version, it might help...But no. Exclamation Exclamation
SO ........what do I do....
I havent made any speciel preferences, so it cant be that...... Question
Anybody?
Upload or download? Please post a log file.
D@rkrunner
When I get the Stream write error, its on downloads. From time 2 time it also claimes a 2. error. invalid memory acces. Ill try 2 find a logfile for later.
OK, I'm waiting for the log.
D@rkrunner
Here it is, or here the most is...the rest was sensitive info..
. Using SFTP protocol.
> Type: SSH_FXP_INIT, Size: 5, Number: -1
< Type: SSH_FXP_VERSION, Size: 5, Number: -1
. SFTP version 3 negotiated.
> Type: SSH_FXP_EXTENDED, Size: 38, Number: 86020552
< Type: SSH_FXP_STATUS, Size: 38, Number: 86020552
< Status/error code: 8
. Server does not recognise WinSCP.
. Changing directory to "/FILENAME".
. Getting real path for '/FILENAME'
> Type: SSH_FXP_REALPATH, Size: 88, Number: 86023696
< Type: SSH_FXP_NAME, Size: 179, Number: 86023696
. Real path is '/FILENAME'
. Trying to open directory "/FILENAME".
> Type: SSH_FXP_OPENDIR, Size: 88, Number: 86027275
< Type: SSH_FXP_HANDLE, Size: 13, Number: 86027275
> Type: SSH_FXP_CLOSE, Size: 13, Number: 86030340
< Type: SSH_FXP_STATUS, Size: 24, Number: 86030340
< Status/error code: 0
. Listing directory "/FILENAME".
> Type: SSH_FXP_OPENDIR, Size: 88, Number: 86033675
< Type: SSH_FXP_HANDLE, Size: 13, Number: 86033675
> Type: SSH_FXP_READDIR, Size: 13, Number: 86036748
< Type: SSH_FXP_NAME, Size: 469, Number: 86036748
> Type: SSH_FXP_READDIR, Size: 13, Number: 86040076
< Type: SSH_FXP_STATUS, Size: 28, Number: 86040076
< Status/error code: 1
> Type: SSH_FXP_CLOSE, Size: 13, Number: 86043396
. Sending null packet to keep session alive.
. Sending special code: 15
< Type: SSH_FXP_STATUS, Size: 24, Number: 86043396
. Startup conversation with host finished.
. File: "/FILENAME"
. Copying "/FILENAME" to local directory started.
. Binary transfer mode selected.
. Checking existence of partially transfered file.
. Resuming file transfer.
. Opening remote file.
> Type: SSH_FXP_OPEN, Size: 114, Number: 86046979
< Type: SSH_FXP_HANDLE, Size: 13, Number: 86046979
> Type: SSH_FXP_READ, Size: 25, Number: 86049797
* (EWriteError) Stream write error
. Asking user:
. Error writting to file '\FILENAME' ("Stream write error")
. 9 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> Type: SSH_FXP_CLOSE, Size: 13, Number: 86067460
< Type: SSH_FXP_STATUS, Size: 24, Number: 86067460
* (EScpSkipFile) Error writting to file '\FILENAME'
* Stream write error
I hope ill do it.. Thx in adwance.
Hmm, that's strange. Have you tried to download the file to different drive?
D@rkrunner
I tried moving my folder to each of my drives. i got the same result. I just got again 2 min. ago.
The strange part is.. Small files..NO problem.
resume transfer no problem
4200 MB big proglem.
OK, I'll try to prepare debug version of WinSCP to trace down the problem. I'll contact you shortly on your email address.
I have send you an email with link to modified version of WinSCP.
niket.save
Helo,
I have facing problem, while data copy from linux to windows machine
After completing copy 97% or 98% they have given error ( Stream Write Error )
Also whenever copy any other small file it will copied properly
Kindly suggest what will i do ?
Regards,
Niket
