Topic "Problem with the Put Statement Using Timestamp"
DWVZ2000
I am having a problem putting a file to an SFTP site using the PUT command.
I am new with Winscp, but I have used the Put command successfully in other scripts. I am using Winscp Version 5.7.4 and Windows 7. Below are the two scripts that I have tried. I get folder/file not found or some other messages.
1st One:
="C:\Program Files\WinSCP\WinSCP.exe /console /command ""option confirm off"" ""open MySession"" ""put \\abc-dr\DailyFiles\Inpatients Daily Report-"%%TimeStamp#yyyy-mm-dd%%".csv"" "
2nd One:
="C:\Program Files\WinSCP\WinSCP.exe /console /command ""option confirm off"" ""open MySession"" ""put \\abc-dr\DailyFiles\Inpatients Daily Report-" & Format(Now(),'yyyy-mm-dd') & ".csv"" "
Thanks for any help you can give.
David
Duplicate post:
http://winscp.net/forum/viewtopic.php?t=15695
