Topic "Sync directory tree to single dir?"
kleach
Is there a way I can sync a whole directory tree into one directory on the remote site?
-Ken
Sync or copy (upload)?
redlav
Hello, I have coincidentally the same problem.
I have created a folder structure that is used for better overview.
Changes to files (change / delete / new) are to be synced in a single
directorie for further processing in this structure.
regards redlav
Again, sync or plain copy (upload)?
redlav
the transfer will take place in Sync mode. All changes should be applied to the target directory. In other words, no longer existing files in the source will be deleted from the target.
Thank you very much for your efforts.
regards redlav
No WinSCP cannot do this automatically.
Though scripting this in a PowerShell using WinSCP .NET assembly won't be that difficult.
redlav
I have no idea how I could solve the problem with .NET.
Is there a code example where I could get my bearings?
regards redlav
You can start with this example:
http://winscp.net/eng/docs/library_example_recursive_download_custom_error_handling
Modify it to download the files to a fixed folder in session.GetFiles call.
regards redlav
Hi redlav, did you get it to work?
