Topic "Batch file containing email address as username"
Could someone please look at this syntax and let me know if its wrong as its not working.
Im using latest version of WinSCP on Windows 7, and I'm trying to use a windows scheduled task to download filed from a remote ftp folder every hour.
My ftp host requires that usernames be in the form of email addresses.
The command line I'm using is this:
/command "option batch abort" "option confirm off" "open" "get MONITORED-VT-FOLDER-CAUTION/*.ext C:\Users\Admin\Desktop\Presenters\download+folder\" "exit"
Any ideas?
The correct syntax is
Though WinSCP should handle your syntax too.
So the problem is probably elsewhere.
What does not work, specifically?
