Topic "Can't Duplicate File on Server"
Dereta
Hey Everyone, i have a Problem on Duplicating files..
On one of my Server i can Duplicate (per rightclick & hotkeys) on an other server i can't.
It will Stop at this Message (Screen)
After 15 Seconds i get this Error:
I Try a lot of things <.< but nothing works... Anyone have a idea?
To duplicate the files in-place WinSCP needs to open a separate shell session:
http://winscp.net/eng/docs/shell_session
It does not work with your server.
Difficult to tell why without a log file.
In any case, you can duplicate the file via a local temporary copy:
http://winscp.net/eng/docs/ui_duplicate
Dereta
Where can i find the Log files? I can just use the first way you say. Because the file are to large to download and reupload.. <.<
Greatz
Dereta
So.. here is the log.. i hope you can find the error :/
M2Oldin-Hauptroot.log (117.08 KB) Private file
Description: Log from Duplicate File error
Thanks for the log.
Can you try to set UTF-8 encoding for files names to Off or On (not the default Auto)?
http://winscp.net/eng/docs/ui_login_environment
Dereta
Does help Shocked
Thanks you a lot! Smile
