Topic "Can Winscp be used to sync between two local folders on the same pc"
bob parkes
I have used winscp before to synchronize between a local folder and a
folder on a remote machine. I found the synchronize feature very easy to use,
and I am familiar with it
Because of the ease of use, I would like to use winscp for a slightly different task:
to synchronize between 2 local folders, each on a different logical disk
(for example c:\my_data and d:\my_data, on my PC)
Because both folders are local, I think there is no remote host, and so no need for
remote login or for ftp, so I do not know whether it is possible to use winscp for this task
Can you advise me please ?
yours sincerely, Bob Parkes
Using WinSCP 4.1.8 on Windows 7 enterprise edition
WinSCP does not support synchronization of two local folders.
Side note: You really need to upgrade!
