Topic "WINSCRIPT file"
ash
I am new to this winscript and need some help. I want to upload file from my server to SFTP server and then delete the file from local directory.
I created this script which upload the file ftp server without any issue but i am not able to perform the delete step using put- delete command .
option batch abort ------------ THIS SCRIPT WORKS FOR FILE UPLOAD
open sftp://xxx:xx@1xx.247.162.2xx
cd //Locations
put C:\test.txt
close
But when i add the delete option with PUT command then it donot works
option batch abort ------------ THIS SCRIPT DONOT WORKS FOR FILE UPLOAD and DELETE
cd //Locations
put -delete C:\test.txt
close
Can some please review my script and let me know what missing in order to achive delete process once file is uploaded
The script looks correct.
