Topic "certificate in batch script"
landersson
command:
open "ftps://userpasswordserver" -implicit -certificate="fingerprint"
works fine in version 5.5.2, but not in any newer version.
What does it do?
Further info.
It works fine in the GUI, but not in batch command mode
And the log file? Both for GUI and script, please
