Topic "keeping filters"
Hubert
I am synchronising a local folder with a web site.
I connect, type ctrl-S, and filters are gone.
I retype them :
| *.cur; *.db; *.js; dotclear2/
I clic OK,
then it works, but the mask is NOT memorized, even if I clic on the little square to use same parameters next time.
I think it is a bug...
Hubert-lelong
Problem solved.
can't delete post, but I found the way, not a bug, just a bit complicated...
