Topic "Setup can't create "C:\Program Files (x86)\WinSCP""
jaymax36
Win 8.x platform:
WinSCP 5.7.4 became unstable - frequent re-connections required.
Decided to upgrade to v. 5.7.5.
First attempt failed with the following ==>
Setup - WinSCP
Setup was unable to create the directory "C:\Program Files (x86)\WinSCP".
Error 5: Access is denied.
OK
Deleted the 5.7.4. with the control panel, hoping for a clean install ==> the same results.
What is the solution?
Thanks!
When you run the installer, do you get a "User Account Control" popup?
jaymax36
Interesting question - The honest fact is that I do not know - was not observant enough. What I did was to install as another "administrator".
Can you reproduce the problem?
jaymax36
I would have to clobber my existing installation with the other Administrator? Is it worth it? should I?
Re-installing WinSCP does not break anything.
