Topic "Weird bug with opening and reloading some files"
youradds
For some reason (since the last update I think), I've been getting weird errors like:
Can't create file 'C:\Users\Andy\AppData\Local\Temp\scp02808\srv\www\site.net\www\cgi-bin\admin\templates\shared\Directory\modify_dir.html'.
System Error. Code: 1224.
The requested operation cannot be performed on a file with a user-mapped section open
I also get errors when trying to save the files in my editor. I have attached 2 screenshots for you, to show what I get. Hope that helps!
Anyone got any ideas?
FWIW I upgraded to Win10 recently - but it was working fine for a while since then. It only seems to have become an issue with the last upgrade I did.
TIA
Andy
ScreenShot 2015-08-21 at 14-32-14.jpg (26.97 KB)
Description: Message when trying to save a changed file
ScreenShot 2015-08-21 at 14-32-39.jpg (49.25 KB) [Download]
Description: 2nd message I get (when trying to re-open the file)
Do you get this every time or randomly? What upgrade do you mean? Upgrade of WinSCP? From what version?
youradds
I'm now on 5.7.4 (not sure what I was on before, but I do remember upgrading recently)
I can't seem to see a pattern - but if I do, I will let you know Smile
Cheers
Andy
