Version of SFTP protocol in command line
steph78630
we use WinSCP on the command line (scripted) with SFTP version 3 for broadcast on customers NAS.
Since NAS delivery with the new firmware, it select alone WinSCP SFTP version 6 (Version "favorite?), that version crashes the operations of copy and synchronization...
Is it possible to use a switch to force the use of WinSCP.com with SFTP version 3 (and not 6)?
Thank you in advance for your answers,
Steph
Re: Version of SFTP protocol in command line
See https://winscp.net/eng/docs/rawsettings
Please provide us a log of the problem with version 6 first.
