Topic "Cannot List Directory & No Such File or Directory Error"
Grit
While creating some automated scripts with WINSCP, I've encountered a problem with a specific SFTP site that has me bewildered. There are no issues whatsoever when using the WINSCP gui (winscp.exe) - however I'm trying to use winscp.com.
After navigating away from the root directory of the SFTP site, the "ls" command no longer functions, and simply throws an error message "Directory X does not exist".
Additionally, and more troublesome is the fact that I cannot navigate or pull files from specific directories. Again, a similar error message "Cannot get real path for X" is thrown.
In the log file you will note that I can navigate to "/prod/wim_out/lincoln", but I cannot navigate to "/prod/wim_out/cornerfeedfiles" and several other folders.
These directories are set-up with identical permissions, and FTP clients can access them with no problem. It's only when I use command-line options and scripts that this problem is encountered.
Any help that can be provided is appreciated.
log.txt (14.47 KB) [Download]
Description: Session log
Grit
I'm on the latest version of WINSCP, but this problem existed in the prior version as well.
Can you attach a log file from GUI showing listing of the /prod directory?
See attached GUI log file - shows directory listings.
log.log (10.17 KB) Private file
Description: GUI Log
Grit
FYI - I tried with an older version of WinSCP (5.5.6) and the same problem was present. I've also tried from different computers in different networks.
It's a third-party FTP site, so I'm limited in what I can look at there.
In GUI, you enter /Prod path, while in script you use /prod. Note that most servers are case-sensitive.
Grit
Well that was simple. Turns out that you're right.
If I use improper case with a cd command, I'm still able to navigate through folders up to a specific point where it starts to fail. However, I can't list the contents in those directories unless I used the proper case to begin with.
It's a little bit counter-intuitive, but using the correct case seems to be the solve. And I could have sworn I tested that. Oh well.
Thanks!
