Topic "[VB6] Connect By ID and PPK file"
mybaek
Hello Smile
Thank you for for your precious time.
I have a SFTP Connection ID and .ppk File for SFTP Connect (exclude Password).
And I want to make VB6 code for Connect and Upload file by ID and .ppk file(ppk file path)
I find example about SFTP Connect and apply then, But It doesn't work.
Here's the VB code that I need help.
' Connection Option
    Dim session
    Dim sessionOptions
    Set session = New session
    Set sessionOptions = CreateObject("WinSCP.SessionOptions")
    Dim myTransferOptions As New TransferOptions
     With sessionOptions
        .Protocol = Protocol_Sftp
        .HostName = "SFTP Address"
        .UserName = "SFTP Connect ID"
        .SshPrivateKeyPath = "Full Path of .ppk File"
    End With
    ' Binary Mode
    myTransferOptions.TransferMode = TransferMode_Binary
   ' Connect
    session.DisableVersionCheck = True
    session.Open (sessionOptions)
I am looking forward to your reply.
Sincerely.
