Topic "Existing files only command line syntax"
kleach
I am running an automated script to up sync files in a directory tree.
The source has gone crazy and has terabytes of garbage files.
I want to build a new directory tree locally and just make/"touch" an empty file with the proper name and old date..
then I wan to update JUST THE FILES in my new directory tree with what is at the source.. if they are different.
I see in the doc a reference to "Existing files only" but do not see the command line or script option ?
What am I missing?
point 2: I would also like to request a feature... I think it would be a nice feature to supply a text file containing the directories and file names to sync. It would require new options on the command line like -sourcefilelist and -targetfilelist SourceFilelist would contain something like:
etc..
it would give the ability to build a list of the exact files you need to sync that do not fit in a wildcard or other common selection process.
point 3: The search feature on this web site (with chrome) does not work for me.. says loading with no results no matter what I search for.
Prophesix
What os are you using? I had a similar issue with a few Windows directories and found that Xcopy did just the trick.
Sorry, I just do not understand what you are trying to do.
Anyway...
There's no equivalent in scripting. But you can set the option in GUI as default and the script will use it.
etc..
You can do it like:
http://winscp.net/eng/docs/script_upload_file_list
