Topic "Need to make script for automating file transfers as provided."
kevs02
I'm sorry, I'm a noob at this. I've read but still not quite understanding how this works. I need to write a script to update files on the distance server when files are updated locally using the same name for multiple files. meaning each file name will remain the same all the time. My major problem is not understanding how the notepad is incorporated into WinSCP.
Notepad is a text file editor.
You may use it to create/edit scripts for WinSCP (which are text files).
But you can use any other text file editor.
