Topic "dot net process is succesfull but file is not getting copied to destination (no error)"
swamytech
We are trying to copy the file from local system to SFTP site. Process is successful but file is not reaching destination location.
Here is the code:
try
Protocol = Protocol.Sftp,
HostName = XYZ //Testsftpsite.com
UserName = XYZ
Password = XYZ
PortNumber = XYZ
SshHostKeyFingerprint = XYZ
'ALL XYZ are replaced with actual values
session.Open(sessionOptions);
bool blConnectionStatus = session.Opened;
TransferOptions transferOptions = new TransferOptions();
transferOptions.TransferMode = TransferMode.Binary;
transferOptions.FilePermissions = null;
transferOptions.PreserveTimestamp = false;
transferOptions.ResumeSupport.State = TransferResumeSupportState.Off;
TransferOperationResult transferResult;
transferResult = session.PutFiles(LOCALFilePath,RemoteFilePath,false,transferOptions);
transferResult.Check();
catch (Exception ex)
MessageBox.Show(ex.Message.ToString());
Using WinSCP 5.7.4.0 on Windows 8 / 64 bit system.
Please help us to resolve the issue
code.txt (1.28 KB) Private file
Description: Code
swamytech
Thanks for the support. I'm attaching the code details which we have used
Status_Code.txt (2.31 KB) Private file
Description: Enabled the SessionLog and attached code which we have used to tranfer the file
swamytech
Thanks for the support. I'm attaching the details of session log file which you have requested.
Log.txt (10.01 KB) Private file
Description: Session log file details
The file is transferred. It's possible that you have wrong syntax of remote path, but I cannot tell as you have obfuscated the path. Make sure the path ends with slash or file name. Or there's some server-side process that removes the file as soon as it is uploaded.
