Topic "error message when opening session "No argument for format 'System Error, Code: %d. %s%s'""
Here is the command line passed and the error message, please help me:
open "%remote!connection%" -privatekey="%private_key%"
here is the error message:
Searching for host...
Connecting to host...
Using username "xxx"
Authenticating with public key "rsa-key-20141021".
Starting the session...
Session started
No argument for format 'System Error. Code: %d. %s%s'
Active session: xxxxxxxxx
then script exit
