Topic "Login with 2 key factor RSA Token"
rgeo
I am using the Winscpnet.dll for the first time.
Here's my code..
I keep getting an error access denied when I run the code below.
When I login through Winscp.com & Winscp.exe, providing the same hostname username password & Passcode I am able to login successfully
strWinSCPDllPath= (WINSCPNET.DLL path)
Set SCPSessionProtocol = DotNetFactory.CreateInstance("WinSCP.Protocol", strWinSCPDllPath)
Set SCPSessionOptions = DotNetFactory.CreateInstance("WinSCP.SessionOptions", strWinSCPDllPath )
Set SCPSession = DotNetFactory.CreateInstance("WinSCP.Session", strWinSCPDllPath)
'Setup session options
With SessionOptions
.Protocol = SessionProtocol.sFTP
.HostName = &Hostname
.UserName = &Username
.Password = (PASSCODE-RSA Token)
.GiveUpSecurityAndAcceptAnySshHostKey = true
.SshPrivateKeypassphrase = (PASSWORD)
End With
else
msgbox "Protocol not accepted"
End If
'Connect to the server
SCPSession.SessionLogPath= "Path"
SCPSession.Open SCPSessionOptions
If SCPSession.opened Then
msgbox " Connection Successful"
Else
msgbox "Connection failed: " & Err.Description
End If
Any help appreciated
Rgee
Enable password logging:
SCPSession.AddRawConfiguration("Logging\LogSensitive", "1")
See http://winscp.net/eng/docs/rawconfig
And inspect the session log file, if a correct password is used.
If that does not help, please attach the log. You remove any data you consider sensitive. If you do not want to post the log publicly, you can mark the attachment as private.
