Topic "schedule task automation problem"
paulbluicouk
Hi People,
I am attempting to create a scheduled task that will pull down all the folders and files created in the last 24 hours.
I have managed to get to a point where I can seeming get all the files in the ftp server, using this...
/log=A:\ALLFTP\winscp.log /command "option batch abort" "option confirm off" "open ftp://user:password@myftpdomainname.co.uk/" "get * A:\ALLFTP" "exit"
However I am having no end of issues trying to get the files and folders created in the last 24hours or 1d, I had expected this to work...
/log=A:\ALLFTP\winscp.log /command "option batch abort" "option confirm off" "open ftp://user:password@myftpdomainname.co.uk/" "get *<1d A:\ALLFTP" "exit"
But again no joy it simple starts to pull down everything.
I would appreciate any help or advice you could offer as I have been going round in circles trying to figure this out.
Thanks Paul
It should be *>1d, not *<1d.
See http://winscp.net/eng/docs/file_mask#size_time
paulbluicouk
Hi Prikryl,
I appreciate your input but even when I change it as you suggested I still receive everything in the directories, not the files only created in the last 24 hrs.
Thanks Anyway
I hope you can image that it's difficult to help, if you just tell us "it does not work".
