Topic "Error changing to directory - WebDav Host"
dnmadc
I'm trying to connect to a WebDav host using the same configurations that is working on other FTP/WebDav client (BitKinex) but I'm getting the following error message "Error changing to directory - 405 Method Not Allowed". The host settings are similar on WinSCP and BitKinex, so I'm really not sure what can be wrong - Next you can check the WinSCP log:
WinSCP Version 5.7.5 (Build 5665) (OS 10.0.10240 - Windows 10 Pro)
Configuration: HKCU\Software\Martin Prikryl\WinSCP 2\
Log level: Normal
Local account: DAC_Laptop\Duarte
Working directory: C:\Program Files (x86)\WinSCP
Process ID: 8808
Command-line: "C:\Program Files (x86)\WinSCP\WinSCP.exe"
Time zone: Current: GMT+1, Standard: GMT+0 (GMT Standard Time), DST: GMT+1 (GMT Daylight Time), DST Start: 29/03/2015, DST End: 25/10/2015
Login time: 18 de setembro de 2015 14:04:50
Session name: Logiberica (Modified site)
Host name: www.logiberica.info (Port: 80)
User name: clientes (Password: Yes, Key file: No)
Transfer Protocol: WebDAV
Proxy: none
Local directory: C:\Users\Duarte\Documents, Remote directory: /clientes/, Update: Yes, Cache: No
Cache directory changes: No, Permanent: Yes
DST mode: 1
Compression: No
ah_create, for WWW-Authenticate
Sending request headers:
OPTIONS /clientes/ HTTP/1.1
User-Agent: WinSCP/5.7.5 neon/0.30.1
Keep-Alive:
Connection: TE, Keep-Alive
TE: trailers
Host: www.logiberica.info
Sending request-line and headers:
Doing DNS lookup on www.logiberica.info...
req: Connecting to 31.193.141.145:80
Request sent; retry is 0.
[status-line] < HTTP/1.1 401 Authorization Required
Header Name: [date], Value: [Fri, 18 Sep 2015 13:04:51 GMT]
Header Name: [server], Value: [Apache]
Header Name: [www-authenticate], Value: [Basic realm="clientes"]
Header Name: [content-length], Value: [401]
Header Name: [connection], Value: [close]
Header Name: [content-type], Value: [text/html; charset=iso-8859-1]
End of headers.
ah_post_send (#0), code is 401 (want 401), WWW-Authenticate is Basic realm="clientes"
auth: Got challenge (code 401).
auth: Got 'Basic' challenge.
auth: Trying Basic challenge...
auth: Accepted Basic challenge.
sess: Closing connection.
sess: Connection closed.
auth: Sending 'Basic' response.
Keep-Alive:
TE: trailers
Authorization: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
[status-line] < HTTP/1.1 200 OK
Header Name: [allow], Value: [GET,HEAD,POST,OPTIONS,TRACE]
Header Name: [content-length], Value: [0]
Header Name: [content-type], Value: [httpd/unix-directory]
End of headers.
ah_post_send (#1), code is 200 (want 401), WWW-Authenticate is (none)
Request ends, status 200 class 2xx, error line:
200 OK
Request ends.
Using WebDAV protocol.
Doing startup conversation with host.
Changing directory to "/clientes/".
Trying to open directory "/clientes/".
<?xml version="1.0" encoding="utf-8"?>
<propfind xmlns="DAV:"><allprop/></propfind>
PROPFIND /clientes/ HTTP/1.1
Connection: TE
TE: trailers
Depth: 0
Content-Length: 84
Content-Type: application/xml
Sending request body:
[status-line] < HTTP/1.1 405 Method Not Allowed
Header Name: [date], Value: [Fri, 18 Sep 2015 13:04:52 GMT]
Header Name: [content-length], Value: [235]
End of headers.
ah_post_send (#0), code is 405 (want 401), WWW-Authenticate is (none)
Request ends, status 405 class 4xx, error line:
Request ends.
(ECommand) Error changing directory to '/clientes/'.
Getting current directory name.
Connection: TE
TE: trailers
Depth: 1
Content-Length: 84
Header Name: [date], Value: [Fri, 18 Sep 2015 13:04:56 GMT]
End of headers.
Request ends.
(ECommand) Error listing directory '/clientes'.
Startup conversation with host finished.
Not refreshing directory, caching is off.
The log from BitKinex, that connects without problems is the following:
Resolving host name "www.logiberica.info" ...
Connecting ( www.logiberica.info => ip: 31.193.141.145, port: 80 )
Connected (31.193.141.145:80)
<<< GET /clientes/ HTTP/1.1
<<< Host: www.logiberica.info
<<< User-Agent: BitKinex/3.2.3
<<< Accept: */*
<<< Pragma: no-cache
<<< Cache-Control: no-cache
>>> Date: Fri, 18 Sep 2015 12:51:53 GMT
>>> Server: Apache
>>> WWW-Authenticate: Basic realm="clientes"
>>> Content-Length: 401
>>> Connection: close
>>> Content-Type: text/html; charset=iso-8859-1
Connection closed
<<< Accept: */*
<<< Authorization: Basic Y2xpZW50ZXM6dWcwVWRPakZWX2s=
>>> HTTP/1.1 200 OK
>>> Server: Apache
>>> Content-Length: 5274
>>> Connection: close
>>> Content-Type: text/html;charset=UTF-8
FIN received
Connection closed
<<< HEAD /clientes/Arvore_FTP_Logiberica.pdf HTTP/1.1
<<< Accept: */*
<<< Translate: f
>>> HTTP/1.1 200 OK
>>> Server: Apache
>>> Last-Modified: Thu, 04 Sep 2014 15:55:30 GMT
>>> ETag: "1840076-18435-5023f61cef893"
>>> Accept-Ranges: bytes
>>> Content-Length: 99381
>>> Connection: close
>>> Content-Type: application/pdf
FIN received
Connection closed
Con someone help me in figuring out why is the WinSCP connection not working?
Best Regards,
Please show us BitKinex log for comparison.
dnmadc
Hi, The BitKinex log was already in my original post - please check below the BitKinex log for the successful login to the webdav site/folder:
<<< Accept: */*
>>> Server: Apache
>>> Content-Length: 401
>>> Connection: close
Connection closed
<<< Accept: */*
>>> HTTP/1.1 200 OK
>>> Server: Apache
>>> Connection: close
FIN received
Connection closed
<<< Accept: */*
<<< Translate: f
>>> HTTP/1.1 200 OK
>>> Server: Apache
>>> Connection: close
FIN received
Connection closed
Thank you for your help.
It does not look like a WebDAV. You do not use GET request to list WebDAV folder. In WebDAV, there's PROPFIND request.
BitKinex claims to be an HTTP client. So it possibly can parse a directory listing page produced by an HTTP server.
Thank you for your help. I'm not an expert on these kind of connections, so does this means that I cannot connect to this specific host using WinSCP?
Best Regards,
Most probably you cannot.
