Topic "When uploading large files Say 200-300 MB using ,net Library it fails with error code 4"
coolshashi
I get an exception and transfer of file fails when using WinSCP .net version 5.7.5
I am using SynchronizeDirectories method.
It has no issue uploading smaller files.
I get errors sometime with FileZilla too but it seems to (Error: error while writing: failure") to correct itself and succeed uploading the file.
Please help.
Shashi
coolshashi
The error message I get is
Upload of \\ProjectFiles\2015.09.01_5509\C6KA.zip failed: WinSCP.SessionRemoteException: Cannot close remote file 'C6KA.zip'. ---> WinSCP.SessionRemoteException: General failure (server should provide error description).
Error code: 4
Error message from server: Failure
Well, it's obviously a server-side problem. So please contact a server administrator first.
coolshashi
Thanks a lot for the reply. But I never get any issue with FileZilla finishing the job. Even if I see some errors it seems to finish.
I copy using FileZilla. Not synchronize.
For a new directory is it better to try copying instead of snychronize ?
Is there any difference using the WinSCP.exe with command line to .net library ?
Are there any additional flags that only availabele in command prompt that can help me ?
Shashi
coolshashi
I also see a .filepart file on the remote server when the error happens. Does this mean it has issues renaming that .filepart file to what ever the real extension ?
coolshashi
I am pasting my code here for you to look at so that you can tell me if there is anything i am missing.
remoteSession_FileTransferred errros out consistently on a large file. Once it has errored out on a file it seems to keep doing that when i re try too.
The file it gives me trouble is around 198MB and it fails around 187MB. I see a 187MB file that has .filepart extension of remote site.
private void SyncFolders(string srcPath, string dstPath, bool bCreateDestFolder = false)
            if (Directory.Exists(srcPath))
                if (bCreateDestFolder)
                    if (!remoteSession.FileExists(dstPath))
                        remoteSession.CreateDirectory(dstPath);
                remoteSession.SynchronizeDirectories(SynchronizationMode.Remote, srcPath, dstPath, true);
        private void ReleaseSoftwareToLfoundary()
            UpdateStatus("Updating LFoundry FTP Site ..Please wait");
            WinSCP.SessionOptions sessionOpts = new SessionOptions();
            sessionOpts.HostName = "sftp.lfoundry.com";
            sessionOpts.PortNumber = 7788;
            sessionOpts.UserName = "username";
            sessionOpts.Password = "password";
            sessionOpts.Protocol = Protocol.Sftp;
            sessionOpts.GiveUpSecurityAndAcceptAnySshHostKey = true;
            sessionOpts.TimeoutInMilliseconds = 500000;
            bFTPFileTransferError = false;
            remoteSession = new Session();
            remoteSession.FileTransferred += new FileTransferredEventHandler(remoteSession_FileTransferred);
            remoteSession.Open(sessionOpts);
            int nCount = 0;
            while (remoteSession.Opened == false)
                Thread.Sleep(200);
                nCount++;
                if (nCount == 25)//wait for 5 secs
                    itemsFailed++;
                    AppendToLog("Connecting FTP server Failed");
                    return;
            try
                srcPath = PublishFolder + @"ProjectFiles\" + VersionNumber;
                dstPath = @"ProjectFiles/" + VersionNumber;
                SyncFolders(srcPath, dstPath, true);
            catch(Exception _ex)
        private void remoteSession_FileTransferred(object sender, TransferEventArgs e)
            if (e.Error != null)
                bFTPFileTransferError = true;
                string message = string.Format("Upload of {0} failed: {1}", e.FileName, e.Error);
                AppendToLog(message);
            else
                string message = string.Format("Trasfered file {0} To FTP Site", e.FileName);
coolshashi
I also tried switching off TransferResumeSupport, but Still I get teh same issue.
With
transferOptions = new TransferOptions();
transferOptions.ResumeSupport.State = TransferResumeSupportState.Off;
remoteSession.SynchronizeDirectories(SynchronizationMode.Remote, srcPath, dstPath, true,false, SynchronizationCriteria.Time, transferOptions);
[/code]
You wrote that FileZilla has the problem too. The difference might be that FileZilla just displays the error and continues.
No. The error occurs when the uploaded file (the .filepart) closes. So WiSCP won't even try to rename the file.
coolshashi
The issue was with the space on the FTP site. Had trouble catching hold of FTP site owners to verify and create more space.
Thanks a lot.
