Topic "Scripted backup configuration"
rvoyek
Is there a way to script the export/backup of the configuration? I'd like to setup a scheduled task to do this if possible.
If you are using a registry storage, just use Windows reg.exe command to export HKEY_CURRENT_USER\SOFTWARE\Martin Prikryl\WinSCP 2.
If you are using an INI file, just backup that.
