Topic "Download files similar to GUI in command line"
pb_bmays
I have a working script to download over 300 files on a nightly basis. It is taking over 6 hours to download the files because it is doing it one at a time. Is there any way to perform the download similar to the GUI where I can create multiple download threads using the WinSCP commands? In the GUI, I told the app to transfer in the background individually with a max thread count of 3.
Here is my current script with the SFTP info "X"d out.
# Automatically continue script on errors
option batch continue
# Connect using a password
# open sftp://user:password@example.com -hostkey="ssh-rsa 2048 xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx"
# Connect
open sftp://XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
# Force binary mode transfer
option transfer binary
# Download file to the local directory
get -resume -resumesupport=on *.zip Z:\*.zip
# Disconnect
close
# Exit WinSCP
No, the scripting does not support parallel transfers.
I have added an example how to implement this in PowerShell using WinSCP .NET assembly:
https://winscp.net/eng/docs/library_example_parallel_transfers
squa89_
That link doesn't seem to be working- can you double check?
Oh, sorry, corrected.
