Topic "Get -delete not deleting remote files"
sublimnl
I've been working all afternoon to get this working. I just want to download files from a remote server and delete them when done. I finally got everything working, except the -delete option will not do anything. Here is the command I am using:
get -delete -resume -filemask="*.jpg| .*/" * D:\Test\
The jpg files are downloaded and hidden directories are excluded, but the jpg files are never deleted. Any ideas? I tried logging my output to see if that raised any clues, but nothing is even mentioned in the log about deleting the files.
Thanks!
sublimnl
Not sure why, but today it is working perfectly. I did not change anything from last week to today. If it starts happening again then I will post a log.
sublimnl
OK, its not working again for some reason. Please see attached log. I am running the following command:
winscp.com /script=c:\users\home\Documents\WinSCP\django-sync.txt /log=c:\users\home\winscp2.log
Here are the contents of django-sync.txt:
open scp://syncuser:password@django.ayas.cc
option batch on
cd /var/opt/Downloads/
get -delete -resume -filemask="*.txt| .*/" * D:\Test\
winscp2.log (35.71 KB) Private file
Description: (none)
OK, it's due to how an SCP protocol works. When downloading a folder, it deletes the whole folder only after it is completely retrieved. If some files fail to download or are excluded (your case), the folder is not deleted.
If you switch to an SFTP protocol, it would work as your expect.
