Topic "Synchronize keeps getting error"
I keep getting the following trying to sycnhronize local from a web server. The typical end of the log file looks like:
. 2015-10-01 15:52:16.713 Could not retrieve directory listing
. 2015-10-01 15:52:16.714 Asking user:
. 2015-10-01 15:52:16.714 Error listing directory '/Websites/Site1/wwwroot/bin'. ("Could not retrieve directory listing","Transfer OK")
< 2015-10-01 15:52:16.714 Script: Error listing directory '/Websites/Site1/wwwroot/bin'.
< 2015-10-01 15:52:16.714 Script: Could not retrieve directory listing
< 2015-10-01 15:52:16.714 Transfer OK
. 2015-10-01 15:52:16.716 Script: Failed
> 2015-10-01 15:52:16.716 Script: exit
. 2015-10-01 15:52:16.716 Script: Exit code: 1
. 2015-10-01 15:52:16.718 Disconnected from server
The thing is, it connects fine, downloads some files from the directory above, but on any particular file can fail on the above. Doesn't seem to be repeatable. Any ideas?
My FileZilla server on the web server doesn't display any errors.
