Topic "SFTP Sync Inbound - not bringing data over instead creating 0kb files"
amoha
I am working on SFTP scripts that is supposed to sync files for both inbound and outbound. The inbound sync runs to success. But it fails to sync all files properly. It does not miss the file entirely, but instead creates an empty file of the original file. There is no data in these files on the local machine after the sync from the server. The same files on the server are not empty.
Example after sync is completed:
Server File Server - File Size - Local Machine File - Local Machine File Size
1. File A - 34kb - File A - 0kb
2. File B - 64kb - File B - 0kb
3. File C - 26kb - File C - 26kb
Commands used:
# Automatically abort script on errors
option batch abort
# Connect
open XXX@YYYZZZ.EXAMPLE.COM
############Sync Outbound Folder##############
echo ****************************************
echo *******Syncing Outbound Folder Now********
#Change local directory
lcd \
lcd C:\FTP\Out
#Change remote directory
cd ..
cd ..
cd XXX999/outbound
#Print remote directory
pwd
#Preview Synchronize CURRENT local direcotry to remote directory
synchronize remote -preview
pwd
#Synchronize local folder C:\FTP\Out to remote directory
synchronize remote C:\FTP\Out
#Print message
echo TRANSFER COMPLETE!
cd ..
cd ..
############Sync Inbound folder################
echo *******Syncing Inbound Folder Now********
lcd \
lcd C:\FTP\In
cd ..
cd ..
cd XXX888/inbound
pwd
#Preview Synchronize CURRENT remote direcotry to local directory
synchronize local -preview
pwd
#Synchronize remote folder to local directory C:\FTP\In
synchronize local C:\FTP\In /XXX888/inbound
#Print message
cd ..
cd ..
#Disconnect and Exit WinSCP
I cannot afford to miss out these files...
Please review and help. Thank you,
amoha
Thank you for getting back to me. Please see the attached log file. I noticed this happens through the GUI as well when using the explorer. I added some speed restrictions and tried other criteria restrictions to see if it helped. None of the steps seem to help so far.
2015-10-02_0829_ftpscript.log (59.67 KB) Private file
Description: Log File
amoha
Any updates on this? Please help.
Thanks for the log. But I need to know what file you have problem with specifically.
amoha
It varies per log. It could be any file at any given time. It just varies and seems to have a mind of it's own...
Sure. But I need to know what particular file had the problem for that specific run (as recorded in the log).
