Topic "Compress a directory before put command."
Evan Boyd
I'm rather new to all of this but I was finally able to get my game server to auto backup with windows scheduled tasks and WinSCP however, the transfer takes longer than I'd like because of all of the individual files in the directory i'm backing up each night. Is there a way I can compress this prior to it being uploaded to my FTP?
Here is my current Script/Bat
Script
option batch abort
open backups
put "C:\steamcmd\rust\backup\0\TheRustySpittoon_Live\" "/TheRustySpittoon_Live/Backup-%STAMP%"
Bat
@echo off
for /F "usebackq tokens=1,2 delims==" %%i in (`wmic os get LocalDateTime /VALUE 2^>NUL`) do if '.%%i.'=='.LocalDateTime.' set LDT=%%j
set STAMP=%LDT:~0,4%-%LDT:~4,2%-%LDT:~6,2% %LDT:~8,2%-%LDT:~10,2%-%LDT:~12,2%
winscp.com /script=backup_script.txt
I literally have tried everything, I can't get it to even begin to zip a folder the console just instantly closes, with nothing. Any help would be greatly appreciated.
In advanced, thanks
Just use any command-line utility from the batch-file to archive the C:\steamcmd\rust\backup\0\TheRustySpittoon_Live\ before running the WinSCP. Then use WinSCP to upload the archive. This has nothing to do with WinSCP.
Evan Boyd
What has nothing to do with WinSCP, the zipping a folder? Just to make sure I understand you correctly, you suggest having the bat file itself zip the directory, and not the WinSCP script?
What I'm trying to achieve is
Zip the directory
Upload that zip to my ftp
Delete local zip
Exit
This cannot be done with WinSCP?
Sorry, I'm just trying to fully understand...
Evan Boyd
Okay so I've been at this forever and I finally figured it out! I was able to call 7-zip, compress the folder I wanted, generate a temp script on the fly to upload to FTP and it even cleans everything up after.
I'm posting this just in-case anyone in the future needs to do what I needed to.
run.bat
set FileDate=%date:~10,4%_%date:~4,2%_%date:~7,2%
set BackupFile=C:\winscp\Backup_%FileDate%.7z
"C:\Program Files\7-Zip\7z.exe" a -r %BackupFile% C:\steamcmd\rust\server\TheRustySpittoon_Live
rem Generate temporary script to upload %BackupFile%
echo option batch on > script.tmp
echo option confirm off >> script.tmp
echo open backups >> script.tmp
echo put %BackupFile% "/TheRustySpittoon_Live/" >> script.tmp
echo exit >> script.tmp
rem Execute script
"C:\winscp\winscp.com" /script=script.tmp
rem Delete temporary script
del script.tmp
del Backup_%FileDate%.7z
